Cut profile lines showing on PDF print
meabh.morgan234
meabh.morgan234
Hi, I'm a former autocad user and newish to Revit. I've finished planning application drawings 1/100 and construction plans and sections 1/50. I'm hoping to move onto 1/10 details using detail components inserted into my model sections. My cut profile lines are showing in bright green on PDFs and I want to share these with engineer/window contractor etc. Can I hide/change visibility graphics on cut profile lines?
Are they showing black in Revit?
meabh.morgan234
Hi, they are showing bright green on screen and also bright green in my pdf. They are showing in fine view as well as course view. I wondered is it because an element/component has been moved and I just need to re-do/re-align them?
If they are green in revit then the cut profile is not drawn properly.  You may want to edit the cut profile or even delete and redraw it.
meabh.morgan234
Great thanks 🙂
