Cut pattern material doesn't change
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
mairh_tsek
612 Aufrufe, 1 Antwort
Hello all,
I have created this concrete beam. I want  tohave another colour of cut pattern in the projecr. So I edit the family > Properties > Material and I give another colour for 'Beton'.
When I upload the family into the project the colour doesn't change.
I dont have any filter or override.
Is there someone that can 'test' the family?
Thank you in advance!
1 ANTWORT 1
Nachricht 2 von 2
Ilic.Andrej
als Antwort auf: mairh_tsek
Change Béton cut pattern in the project.
Maybe you already had Béton material in the project but then you changed Béton cut pattern in the family editor. Find that material in the project and change it there.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
