Hello all,
I am trying to get the cut pattern to show up as white and it doesn't. I changed it to black and it does.
The roof is black and the wall is gray but I want the wall to be white.
Why can't I get it to show up white?
Any suggestion would be greatly appreciated
Niall
See if your view is set to Coarse Detail Level--if so, try changing it to Medium or Fine. You can keep it at Coarse if you want, and try changing Coarse Scale Fill Color to White. Also, see if you have any Filters in VG that might be overriding the fill to gray. Also check if the wall's Phase is Existing, which could also make if show up gray.
Check to see if the wall has a transparency setting, usually this turns things grey.
Check and see if your object styles have material attached to the roof. Remove it. Also check and see if you have phase filter override.
