Cut pattern in walls but not in Curtain Wall mullions
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1557 Aufrufe, 3 Antworten
In a plan view I want to have a black solid cut pattern on my walls. When I use the View Template to show walls with a black solid cut pattern, the patterns also applies to the mullions in the Curtain Walls (since they are walls) However, I want the mullions to have a white cut pattern. Is there I way i can work around this and make the mullions white?
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
Matt__W
als Antwort auf: Anonymous
You can achieve this by using an override for each. See this short Screencast I created showing you how to do it. Let me know if I've misunderstood.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Nachricht 3 von 4
als Antwort auf: Matt__W
Ah, of course! Thank you!
Nachricht 4 von 4
ryan.duell
As another option you could also add a view filter (to the specific view(s) you wish to show this).  You can create a filter that adds the fill to all walls except a type or types (such as to exclude those particular curtain wall types).  Add the filter to the view and set the overrides as needed.
Ryan Duell
