Cut Pattern Export
5 ANTWORTEN 5
Nachricht 1 von 6
LSN-SR
496 Aufrufe, 5 Antworten
Cut Pattern Export
I've noticed recently that when exporting a file to CAD in meters, the cut patterns are all messed up in Autocad. When the export is done in millimeters the hatch is OK. Is there a solution to export properly in meters? Thank you
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: LSN-SR
have you tried this?
Nachricht 3 von 6
LSN-SR
als Antwort auf: ToanDN
Thank you. Yes, but when I export to meters, when I open the CAD file the patterns are not exported correctly. Strangely enough there is no previous report of this error.
Nachricht 4 von 6
What are your Project Units settings?
Nachricht 5 von 6
LSN-SR
ToanDN thanks for the reply. My units are set to meters in the project. If I export to meters in dwg, hatches like concrete are not exported correctly. If I export in mm, then the hatches display correctly. I am not sure if this is an older bug or a new version issue, but I don't recall having this problem in the past. It's just weird that I have found no complaints about it so far.
Nachricht 6 von 6
LSN-SR
Hello again,
You will find below the original cut pattern in Revit and the "messed" exported version in CAD. I've tried the RegenAll command in CAD, but there might a variable which I am not aware of, or it might be just an export bug. It works fine when exported to millimiters, but sometimes we need to export in meters. Thanks
Revit originalRevit originalCAD exportCAD export
