Cut pattern colour is not correct on exported pdf files
6 ANTWORTEN 6
Nachricht 1 von 7
nozci
284 Aufrufe, 6 Antworten
Cut pattern colour is not correct on exported pdf files and on papers printed within Revit.
The slab is on walls and has a grey solid cut pattern. Revit view is correct.
This is Revit view, which is correct:
The problem is about PDF exports.
PDF export with vector processing,  right hand side wall colour is wrong. It is not coloured:
PDF export with raster processing, this time middle wall colour is wrong. It is not coloured:
When I print to paper it is wrong like raster processing.
I expected I would get what I see. Have you ever had such an issue?
6 ANTWORTEN 6
Nachricht 2 von 7
azad.Nanva
als Antwort auf: nozci
what is your PDF Writer program , maybe you should check the Setup... and Option :
Nachricht 3 von 7
nozci
als Antwort auf: azad.Nanva
I tried Microsoft PDF, PDF-Xchange and actual printer and their options.
Now I installed cutePDF and tried but same thing happens.
Nachricht 4 von 7
azad.Nanva
could you share this part of your work ?
Nachricht 5 von 7
nozci
I can't share it. I am using some workarounds for now. Later I will prepare a small example and if the problem still exists, I share.
Nachricht 6 von 7
TripleM-Dev.net
Hi @nozci,
What's the grey surface, you mentioned a slab, so is it cutting a floor in floorplan?
I would have expected the raster setting to match the revit view. (In the Raster sample the angled lines look smooth, are you sure it's in Raster setting?, I would expect some artifacts...)
Only thing I can think about happening here is (small) scale, some details are then less accurate.
Nachricht 7 von 7
nozci
als Antwort auf: TripleM-Dev.net
Yes, my aim was to show the slabs coloured. When there are different thicknesses any many details it looks clearer.
Yes, I checked raster too. I saw the artifacts. It may not be seen in the post because of the scale.
