Announcements
Cut Line Weight for Structural Framing Girder Sub-Category
Antony.Roy
Antony.Roy
Can someone explain me in which condition this value is useful?
I can't see any views or conditions this number affect the line weight.
Replies (22)
Corsten.Au
What are the object styles if you use default Revit Templates in 2019 version..
There are high chances that upgrading that Revit file to 2019, brought those object styles along with it.
I am just guessing though...
Cheers
Corsten
Building Designer
Antony.Roy
@Corsten.Au Default Object Styles in Structural template from Revit 2019 were shown in my previous printscreen...
Corsten.Au
This might help..
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
The Structural Usage property of a beam is typically automatically assigned based on the structural elements that support the beam. However, structural usage can be changed before or after the beam is placed.
The following table lists the default automatic Structural Usage setting for beams, based on which elements are being connected:
- C B HB G J P O
WallGOHBGJPO
ColumnGOHBGJPO
Brace OOOOOO
Horizontal Brace  HBHBHBHBO
Girder   JJPO
Joist    PPO
Purlin     PO
Other      O
Key. HB: Horizontal Bracing; G: Girder; J: Joist; P: Purlin; and O: Other.
Beams and their structural properties also have the following characteristics:
  • The default Structural Usage setting can be changed using the Properties palette.
  • Beams can be attached to any other structural element, including structural walls, however they will not join to non-bearing walls.
  • The structural usage parameter can be included in a structural framing schedule, allowing quantity calculation of girders, joists, purlins, and horizontal bracing.
  • The structural usage parameter value determines the line style of the beam in a coarse-scale view. Use the Object Styles dialog to change the default styles of structural usage.
  • Beams also have a structural usage as the chords of a structural truss.
Corsten
Building Designer
