Cut_Join Components
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
dm0144
356 Aufrufe, 1 Antwort
Cut_Join Components
Hello everyone!!!
How can I make the right connection between two modeled in place gutters and modeled in place pipe using join or cut tool?
I am attaching an image of the actual joint.
1 ANTWORT 1
Nachricht 2 von 2
bin
als Antwort auf: dm0144
Cut the Gutter 1 using Void 1, Cut the Gutter 2 using Void 2, then cut them using Void 3.
Or you can create the Gutter 1+ Gutter 2 using a sweep, then only need to cut it using Void 3.
Is this a box gutter? You might need sump and overflow?
