Cut hatch patterns do not align with elements when they are applied in filters:
The 2 workarounds provided (changing material hatch pattern - using coarse level display for walls) do not fit our needs.
Does anyone have another third workaround ?
Thank you in advance.
I do not believe that there is... Pattern overrides applied by Filter and more or less similar to Filled Regions with Drafting Patterns. Drafting pattern will not align to element and Horizontal would literally mean Horizontal.
We have done that twice in the past using Dynamo + Python to create a Fill Pattern and View Filters based on wall angle then apply the latter to views.
Ok thank you for the workaround. It's a bit complicated for what we need.
Sincerely
