Cut existing model in place with new voids
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
thomasarnoldsson5732
343 Aufrufe, 2 Antworten
Hi
Is there a way to do a cut through an existing (phase existing) model in place with a new (phase new) void?
I know I can do it if I edit the model i place and adds a void when editing the model in place, but then it ends up in the same phase as the model in place. But I want a new hole in an existing model in place.
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: thomasarnoldsson5732
Not with a void. But you can create a solid form (not void form) mass in the new phase and join it with the existing model in place. Then turn off or hide the mass.
Nachricht 3 von 3
murodesign
als Antwort auf: ToanDN
Hi, i'm sorry to get in this solved topic, but I'm trapped and find no help or clear answer.
Indeed, to cut existing in-place walls (and in my case walls done with in-place mass) I only achieve it as Toan describes, but can't get the infill. The question is, in normal walls, one way of getting the infills resultant of demolition is making a void in a based wall family, so, won't there be a way of making it happen with an In-Place mass also? If not, how do we get the infills correctly, if we can't reproduce the cutted parts manually?
