Cut a Void through Louvre Array
russell.erocido
russell.erocido
I'm trying to cut a void through an array. Attached revit file will show everything better than I can explain. Face based void doesn't seem to work because the array are generic models in an angle relative to the vertical face and I need the void to be on the vertical plane (image attached)
Create it as a curtain wall with only horizontal mullions as louver blades, the edit profile to get it to round shape or any shape you want.
You should be able to. Post your Family here and let's see what's going on.
