Customize door - remove tag
Message 1 of 10
Goodmorning to everybody. I'm simona. I'm new to using revit. i am trying to customize a door. I found on the web a similar to what I need. I modified some elements, the height and the width. Unfortunately, once the door has been positioned, the words: non-standard dimensions  contact sales, appears. I would like to know if is possible to eliminate or make this tag invisible.
Thank you
Replies (9)
Message 2 of 10
RDAOU
@Anonymous
That must be a manufacturer door where they have standard dimensions. In the family they have set and "if" statement which pops the text and sign you see if the dimension of the door is not equal to one of their standard dimensions
Edit the family and look for that if statement and delete it
Delete also the associated parameters with that if statement (text/2D element)
You can also remove the Yes/No parameter associated with the visibility of the text/2D elements
You can post the family if you like and can have a look at it
Message 3 of 10
Thank you to help me. This is the door .
Message 4 of 10
RDAOU
@Anonymous
nothing is attached
Message 5 of 10
Now can you see it?
if is not a problem for you can you tell me also how to remove this parameter, so i can learn for the next time.
Thank you
Message 6 of 10
RDAOU
@votosimona
Delete the following parameters and annotation marked in red as shown below
Message 7 of 10
Thank you. Problem is solved. great to be a part of thid community.
Message 8 of 10
RDAOU
@Anonymous
Check the images below and delete the marked in red
Message 9 of 10
this really helped me thank you so much
Message 10 of 10
danielaperezc0409
Community Visitor
Community Visitor
Hola 5 años después te agradezco tu aporte. Me ha salvado culminando mi proyecto. Mil gracias, pensé que me tocaría cambiar todas las puertas que me presentaban ese problema. Bendiciones.
