Custom Window Family with Visibility Components - Cut wall when visible
2 ANTWORTEN 2
Nachricht 1 von 3
brantyork.design
206 Aufrufe, 2 Antworten
I am building out a window that will have upper and lower trim elements. I would like to be able to turn on and off those trim elements based on there use in various projects. The issue I have is related to the wall cut. I would like to have it occur that when I turn on the trim above the window, that the wall cuts away to make room for the trim. Then if i turn off the upper trim, I want the wall to go back to just cutting out the window itself.
Is there a way to have the cut size of the window family change with the visibility setting of various components within the family?
2 ANTWORTEN 2
Nachricht 2 von 3
linkboy
als Antwort auf: brantyork.design
kind of... Go into wall opening sketch mode add a parameter . See two images below, you may set up the window cut size with gap (fill into the trim) or w/o gap to hug your window frame thru that parameter control. Make your trim controlled by visibility separately, then using family type to group them together. I mean, you can set window trim visibility on and pick the dimension of a bigger window cut, vise versa.trim.jpg
Nachricht 3 von 3
Trim or Frame?
If trim then it wouldn't need to cut wall.
If frame then it is easier to use different families for framed and un-framed types, or use nested families as interchangeable components per the tutorial below:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Revit/f...
