Hi everyone,
I am new in Revit community and have some difficulties with creating custom profile for walls. I want to create cross-section profile and draw several walls. I found out that it is possible to model a shape with "model in place" tool but this gives me only one element, while I need to draw several walls. Can anyone help?
I need several walls with this cross-section.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Duplicate Post.....
https://forums.autodesk.com/t5/revit-structure-forum/wall-cut-profile/td-p/10104728
Howard Munsell
Stack wall is probably the easiest like @ToanDN said. However you can use wall profile embedded into wall as well. As another alternative, you can also use curtainwall to achieve the same result. See attached
I think embedded profile is exactly what I need. Can you tell me how to do it?
You have to edit the wall, then go to section and then add the profile.
You can edit the profile width and height from the project browser>family
