Custom Title Block Sheet
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
mhotwani
524 Aufrufe, 2 Antworten
Hi I have just created custom title block from the Template. It was rft file but now rfa. where do I need to save and second question how do I create other sheet sizes. The one created is an AO.
2 ANTWORTEN 2
Nachricht 2 von 3
Tom_Kunsman
als Antwort auf: mhotwani
I would save the title block in the same directory as the project. If the title block is for a client that you do a lot of business with I would save in a location somewhere you are saving all of your custom revit content.
Each sheet size would be its own file, so now that you have the A0 , I would almost save that one to a new file and then start creating the next size you need.
Nachricht 3 von 3
Rft is the family template. Rfa is the actual family that you can load in
project so you are good to go.
To create a new titleblock size, just save as from the one you have and
edit the border and content to a new dimensions.
