I am trying to create a custom tag that will enable me to display:
The type can be pulled from the family name, which is located within a model group for each unit, as the screenshot shows (3BD - W/B)
I wasn't able to put the solution together based on anything I tried. Any tips appreciated.
Did you look at a Room Tag or Space Tag?
A Multi-Category can report the Family Name and Type if that's all you are looking to do?
...just to be clear: you can pull into a tag through a label a number of different parameters. By the sound of it, a Room Tag has the Parameters you seek. No?
Although they added the option to tag model groups but it is still limited to Family and Type and no possibility to add more...So if you want to stick with Groups you need to fold back to the old workaround of tagging groups...
Cons: Users who will be tagging these in the model need to be aware of what to tag and where to find the designated group element to tag
Alternatively you can use Assemblies instead of Groups. Assemblies allow for a wider otion of Parameters you can use such as Type Mark and Mark similar to the GIF below
Cons: Assemblies cannot include certain elements such as rooms, detail and symbolic items, Text and labels
