Custom Table as a Revit Family
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2969 Aufrufe, 3 Antworten
I have created a revit family and i would like to make an adjustable table within that family (I do not want to use any type of Revit Schedule, i need it to be completely editable). I need to be able to  add/delete rows as necessary. Can anyone help??
See attached images below.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Use a Revit Key Schedule.  It's completely editable, able to add/delete rows, and data is not dependent on model elements.
Nachricht 3 von 4
Viveka_CD
Hi @Anonymous
Wow you are an enthusiast in our Autodesk community!Smiley (fröhlich)
Please look HERE for more information on creating a generic text table in Revit using Schedule Key
Schedule Key has the following advantages
  • Allows you to sort (good for alphabetizing or numbering)
  • Rows always stay the same height and can’t be grabbed accidentally
  • Can break the schedule if it runs off the sheet
However a couple of disadvantages are
  • Not possible to duplicate and create a working schedule, so you have to hide and unhide columns each time you add new information
  • Graphics and font options are limited
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.Kudos welcome!
Nachricht 4 von 4
archie.manza
You can use external application or Revit Add-ins to make it easier see video.
https://www.youtube.com/watch?v=6kvPDOy-vZo
