Can anyone refer to a source to download alternate section marks to the ones provided?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
They are easy to create or Edit/modify the existing Section Heads ... if you have one you like post its pdf someone can help you model it
Alternatively...Each Country Library has different Annotations/Symbols/Section Heads...etc Example below is extracts from the US/UK/German... I know the French Library has different ones but I don't have that downloaded on this laptop you can try downloading those
Where can I find these two families so I can modify them?
Under Families...Annotations ... Callout Head or Section Head
once located, how do you edit these? I can't find a way to open or edit from there.
Like any other Family ... You can start from scratch New Family >> Under the Annotations folder select Section Head OR you edit an existing one as follows:
Additional Resources:
https://youtu.be/4RbqN6_NOvg By the Revit Kid
Click the image below for a short GIF Screen capture
How to edit Section Head Family
It is from the German Library. Copy attached herewith (with translated parameter names for easy editing)
You can switch between Long and short arrow in the Edit Type
Very kind of you to take the time. I modified it a little and it works nicely. Takes a little tinkering with the various kinds of sections to get the various selections right then it's very helpful. I attached my modified family for anyone's use.
I think it will be helpful to have the titles on the section marks, to save rummaging thru sheets looking for which noted sections apply
