Custom Revit Icons for 2023/2024/2025
David_Knight
Message 1 of 37
David_Knight
Was kind of unhappy with the ones I found online.  So I made my own for 2023/2024/2025.
Figured I would share them in case anyone else wanted them as well.
Cant upload ICO files, so they are in the zip.
**Zip files updated to include 2025 Icons**
Replies (36)
Message 21 of 37
zjonesS8KQH
Community Visitor
Community Visitor
Cool, I have been kind of aggravated with finding my shortcut appropriately. This helps a ton.
Message 22 of 37
denise.jonker
Hey David! Loving your icons. Will you be making similar ones for Revit 2026?
Message 23 of 37
michaelburke1114
Hi Denise,
Please scroll down to a previous post from ShiBin_Huang. He has them up to 2028.
Kudos to David & ShiBin!
Message 24 of 37
Claire_Johnston43SMK
Community Visitor
Community Visitor
H! Any chance you could make one for Revit 2022? I know it's being discontinued, but I still use it occasionally, and I would love if all of my Revit icons could match
Message 25 of 37
RSomppi
It's on the first page of this thread, message #14.
Message 26 of 37
aganem5XUT7
ShiBin & @David_Knight  these are awesome, thank you!! Now to figure out where to slap inside the deployment 🤠
Message 27 of 37
Mr.Borges
Well, as I needed custom icons for other Adsk products, I think I've gone a little too far😅.
Enjoy it.
Message 28 of 37
reza.norouziLW6D8
Community Visitor
Community Visitor
Hi David do you happen to have a similar icon for Revit 2026?
Message 29 of 37
David_Knight
I did not create them since the DLL file attached later included it. For me it was a better method than creating an icon file since they were all in the single file.
Message 30 of 37
mirko-viabim_co
What I do (and this may be an idea or suggestion) is using a different colors for icons so there's no mistake on the Revit version I work in.
Often I work in more than one version at once. See the sample:
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
Via BIM: apps.viabim.co
Try my Revit add-ins: Via BIM Tools
Message 31 of 37
ageorgenson
Community Visitor
Community Visitor
David, could you please make an icon file for Revit 2026?
Message 32 of 37
Mr.Borges
Just see my message above, I've created icons for various Autodesk software, including Revit till 2030. It's very similar to David's version. See -> Icons
Message 33 of 37
Sahay_R
Question - does this only change the icon in the desktop shortcut - or will this also affect the icons in the taskbar?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 34 of 37
Sahay_R
@ShiBin_Huang does this process modify the icons on the taskbar? What about the RFA, RTE, RVT icons?
Rina Sahay
Message 35 of 37
nmcclure-TCA
I was able to swap the icon at the desktop app, but it doesn't seem to 'hold' for the tray icon.  It starts out with the custom icon, but then reverts back to the default. Bugger.
Message 36 of 37
colinSRA
Enscape can cause this behavior.
There is a setting called “SuppressTaskbarIconGrouping” that can be controlled with a registry edit.
Refer to the discussion here:
https://forum.enscape3d.com/index.php?thread/28632-enscape-4-0-specifically-4-1-1-why-is-enscape-for...
(scroll down to the response from Demian Gutberlet that contains the registry information)
Message 37 of 37
Mr.Borges
I've been using my .ico pack (you can find them on this thread) for a while on both Windows 10 and Windows 11, and the icons on the taskbar match the icons from shortcuts where the software was launched.
