Custom Mullion Profile - How to mitre corners?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
2421 Aufrufe, 4 Antworten
I created 2 custom mullion profiles. One of those profiles is used for the interior mullions and the other is used for the border mullions. My problem is that I can't seem to mitre join the mullions, I can only "break at join" or "make continuous". I don't know if it has anything to do with the type of mullion that it is - I duplicated a Rectangular Mullion and then replaced the profile with my custom one.
Does anyone know how to get them to mitre so that it looks like a continuous frame?
Screenshot attached.
Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
Ilic.Andrej
als Antwort auf: Anonymous
I think we should take a step back...
Is this a railing? Why use curtain wall to create a railing? I don't say its wrong but...
Ok, based on this picture you gave, I assume the panel itself has some sort of a frame which is welded to the main frame, am I right? Why not just play using curtain wall panels. Model a panel which has a "T" frame, then use simple rectangular profile for mullions...
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 5
als Antwort auf: Ilic.Andrej
Thanks for your reply.
In this case it does look like a railing, but we have many cases where we use it as a full partition wall from floor to ceiling.
I didn't think about creating a new curtain wall panel. That's a great idea, thank you!
Nachricht 4 von 5
Here is a different approach using a CW for the panel of the border frame.  This does not require any custom curtain panel family.
Nachricht 5 von 5
als Antwort auf: ToanDN
Thank you! Both ways do the job but I have decided to go with this approach - thank you!
