Custom Materials Applied Across Multiple Families
Duvylove
Duvylove
Hi All,
In my material editor, I have created new custom materials by duplication which I intend to apply to various families I will be creating. Can you briefly explain to me how I need to set up my material assets and library in order to be able to use them across multiple families. Also, I later intend to export these families to AutoCAD and I wish them to retain their materials and textures post export. Is this possible
Any help you contribute regards this will be really appreciated as I am a bit new to Revit materials
I look forward to hearing from you
Thank you
Regards
RC_RVT
Right click on the material you have created in the material browser and add it to your favourites. This then means that every material you add to your favourites will be available in every project/family you are working on. I'm not sure about the AutoCAD question.
RDAOU
@Duvylove
  1. Duplicate the Material and rename it
  2. Check the appearance tab and the asset it is using
  3. If the asset used is the right one which you want (ex: The Chrome - Polished Black in image 1 below which is an asset of Generic Type):
    1. You use the Duplicate Asset in order not to have a conflict with a different material
    2. under Information section (still under Appearance tab) Rename the Asset
    3. Adjest settings as needed
  4. If the asset is not the proper asset or if you tried the above and didnt like the effect (See image 2)
    1. Click Replace this Asset
    2. Go to the Appearance Library (alternatively you can search for a specific type or name)
    3. Select the material type you wish (ex: Metallic Paint)
    4. Select from the list to the right a predefined asset
    5. Click the "Replace Current Asset" button
      • (recomended) Repeat the same steps described in poit 3 (Duplicate...etc) considering that other material in the library could be using that same asset you chose
With regards to Autocad export...materials do not transfer to autocad suported formats (DWG/DXF). In autocad you would get either the 255 Index colors or true colors. For materials to be exported you need a format that supports material export ...OOTB Revit (as far as I know) supports only OBJ export format which exports material.
I am not sure if in 2025 new formats has been introduced but there are plugins which you can buy/use that exports other formats like FBX for instance
RDAOU
More can be said on the subject but there are lots of resources online which you can Watch/Follow
Creating a Material in Revit
Duvylove
Thank you so much for your detailed explanation and recommendation, I will test them ASAP.
Meanwhile, if I am eventually successful with creating these materials, is it possible to share them with other Revit users outside my organisation? if so, how should they configure the materials received from me?
Thanks, in anticipation👍
Regards
RDAOU
@Duvylove
Its not hard you will manage 🙂 and Yes indeed you can share them with others (you should). You can create your own library (see image below) and then select the material you have created >> right click >>  add to your library
If they have images assosiated with them (textures/bumps/cutouts) these you can also add to a specific folder with that library and share them along with it. This way who ever recieve a family or model from you they will have it complete with materials, assets and what is needed to render.
You can also add the physical and/or mechanical properties assets as well if you have them
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
