Custom material parameter in MTO
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
paolo.pozzoli
1332 Aufrufe, 13 Antworten
Hi there,
I'm trying to add a custom material property and I created a shared parameter associated to Materials category.
Now I can see such property from the material browser (lower left icon) and set its value for each material. I did that for a couple materials I need.
I want to have such data accessible in my project so I added a project parameter linked to the shared parameter I created.
Finally I created in my project a MTO schedule for floors (in which the materials I want are used) and inserted such parameter as a new field, but it returns no values.
What am I missing?
Thanks in advance for your help.
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: paolo.pozzoli
What kind of Parameter? Text?
Nachricht 3 von 14
paolo.pozzoli
als Antwort auf: barthbradley
Number, I want to use it as a percentage for calculation.
Nachricht 4 von 14
Huh? Percentage of what? This is a Parameter field added to each Material; no?  Maybe I'm misunderstanding.
Nachricht 5 von 14
paolo.pozzoli
You're correct.
Each material have its own value for this parameter
The value is always 0.xx and expresses the coefficient of additional waste/spare for material calculation.
In the floor MTO I want to retrieve such value to use in in a schedule formula like Material.Area*(1+MaterialWastePercent), returning the overall area including the waste.
Say I have 100sqm floor composed by plastic+ceramic tiles.
In my material property I set 0.05 (5%) waste for plastic and 0.03 (3%) for ceramic tiles.
I expect the formula in MTO read 105sqm for plastic and 103sqm for ceramic tiles.
Hope I was clear enough.
Maybe I'm pushing Revit too much?
Thanks for your help.
Nachricht 6 von 14
Okay, so you have assigned a value to each of these Custom Material Parameters, though the Material Browser, and you are saying that you cannot pull this Custom Material Parameter into an MTO -- or are you saying that the Custom Parameter is showing up in the MTO, but not displaying the Values you assigned to it through the Material Browser?
Nachricht 7 von 14
paolo.pozzoli
The latter, or so it seems since I managed to add a project parameter that refers to the shared material custom parameter.
Now I'm no more at my pc, tomorrow I will send you a couple screenshot to show what I achieved.
Nachricht 8 von 14
paolo.pozzoli
Hi there,
sorry for the late reply.
See link the steps I performed and the results I achieved.
Thanks again for your help.
Nachricht 9 von 14
You missed a step.  Open Material Browser, Select a Material and then click on the "Custom Parameters" button and enter a value for your Shared/Project Parameter.
Nachricht 10 von 14
paolo.pozzoli
That's what I think I did in step C.
As you can see from picture C if I reopen the material browser the value for the parameter is there.
What am I missing?
Nachricht 11 von 14
How did you access  the Material?  Go through Floor Edit Assembly.
Floors:
FWIW: It's anInstance Parameter.
Nachricht 12 von 14
paolo.pozzoli
I went through manage>material browser.
Tomorrow I'll try your advice.
Thanks again.
Nachricht 13 von 14
Thanks again.
It'll work. Promise.
Nachricht 14 von 14
paolo.pozzoli
I finally managed to get the value in my MTO!
The issue was not *where* I went through to entry the values in the material browser.
I got it to work by looking at the last image you posted and I realized your custom material properties was listed among the available fields, whereas I didn't find them mine... or so it seemed.
On a second deeper sight I did find them and the game was done!
My mistake was creating a NEW parameter in my MTO instead of adding a field from the available ones created before.
I took my MTO beyond that at the end and I share with you the final results.
As you can see the fields in light grey are all custom material parameters, while all other ones with bold text are calculated fields.
I then saved it as a view template.
I think this would be very useful for future fast calculations for execution/purchase.
Thanks again for your valuable help for pointing me in the right direction.
