Custom linked model view problem
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
pawel.kS3DHM
282 Aufrufe, 4 Antworten
Hi, i have a big problem with linked model... I want to change linked model view template but i don't see all views from linked model. Where could be a problem? Thank you very much for help!
Views i can set:
Views in linked model:
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: pawel.kS3DHM
@pawel.kS3DHM
The views on the second image (the missing ones) are of a different Type. In other words...If the main model view is a Floor Plan or a Structural (looking Down) you cannot set the Link to Reflected ceiling or Structural (Looking up)
That being said the Structural framing drawings Rzut konstrukcyjny need to be of a similar type to that in the main model view otherwise they will not show on that drop down list
Nachricht 3 von 5
syman2000
In your current project template, did you checked on the view template linked view? I would check it off if you want each of those views to have different linked view.
Nachricht 4 von 5
pawel.kS3DHM
als Antwort auf: RDAOU
Ok, i understand... so i can't use them. Thank you, so i will talk with architects to get more details in views :leicht_lächelndes_Gesicht:
Nachricht 5 von 5
pawel.kS3DHM
als Antwort auf: syman2000
Thank you for answer! Yes i swich off this "overrides rvt links" on my template :leicht_lächelndes_Gesicht: I think the @RDA0U's answer is correct.
