Custom horizontal Curtain wall panel doesn't fall on Center
Radobaran
Radobaran
I've created custom profile to use in my curtain wall. This profile is created on center however when I've placed it to the curtain wall it doesn't fall on curtain wall grid.
See attached picture for clarification of the issue.
Can anyone help?
Do you mean Mullion?  Share the family.
Radobaran
Yes sorry. It should say mullion profile doesn't fall on center.
See attached file.
Here how to fix it.
Radobaran
Sorry for late response.
Seems like you solved it!
However, I can still not get it to work.
Can you describe step by step how did you fixed it?
I have removed the gap and lock the profile to the work plane. But the issue persists.
You need that gap.  Edit the mullion profile and move the top line down a tiny bit so it doesn't touch the ref plane.
Radobaran
Magic!!!
It worked.
Thank you.
