Custom Hatch Pattern that includes text
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
Ian_H
562 Aufrufe, 5 Antworten
We have a hatch file that I believe is an old AutoCAD hatch that has the number 2 and diagonal dashes. We are wanting a similar hatch but with 3 instead of 2. I tried stacking the original hatch, a grey filled area, and the number 3 and then using PyRevit but that didn't work.
PAT files are text documents, so I'm not sure how to get the 3 in there.
Anyone know how I can go about creating one, have one they could share, or have a better solution?
I did find the program 'HatchiKit', but was confused on how to use it.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Ian_H
Draw the number 3 using straight line segments (then you can create a fill pattern using pyRevit.
Nachricht 3 von 6
Ian_H
als Antwort auf: ToanDN
This did occur to me as I figured PyRevit just couldn't read the text since it wasn't linework. I just wasn't sure how well I was going to be able to draw out the 3 with detail lines.
Nachricht 4 von 6
It's not pyRevit fault.  It is that Revit fill patterns cannot contain anything but straight line segments.
Here is a fill region created using pyrevit..
Nachricht 5 von 6
Ian_H
Went down the rabbit hole of recreating all the linework, lol.
Nachricht 6 von 6
Well done.
I just tested pyRevit again, and to my surprise, it CAN take non-straight lines (circles, arcs, ellipses, splines), translates them into straight line segments to create fill patterns.
