Custom Drawing Tags/View Tags - Label to show drawing#, page#, DRWG title, scale
4 ANTWORTEN 4
Nachricht 1 von 5
722 Aufrufe, 4 Antworten
When I am on my sheet, how do I change the drawing view tag to show a bubble containing the drawing number, page reference, then the drawing title above the line and scale under the line? I saw one that I think fits this description in the revit library when I go to "insert", "load family", and find it in the annotations category, there is an error dialog box saying I cannot load it.  What steps do I need to take to load this family into the project so I can use it?
Thank you in advance.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
So the issue is that you cannot load it. What method are you using? Try opening the Family and loading it into project from the Family.
Post it here if you are still having issues.  Also  tell us what Version of Revit you are using.
Nachricht 3 von 5
als Antwort auf: barthbradley
Thank you for the suggestion.  I tried that and even added a line (Between the title and scale portion of the view title), saving it as a new family within the revit library.  I think closed and loaded into project.  When I clicked on the current view title and looked for the newly loaded family in the properties dropdown, it was not there.  I don't think it loaded? Or maybe I am not accessing it from the right place?
I am using Revit 2018.
Nachricht 4 von 5
What is the family's Category?  It should be View Titles.
Nachricht 5 von 5
You need to select a viewport or a view title of a view port and Edit Type., then pick the new View Title type.
