Custom Ceiling Grid Pattern
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
LisaDrago
6462 Aufrufe, 4 Antworten
so - i have been asked if there is a way to create a custom ceiling pattern - 10' of 24" then 1' of 12" and have it repeat.
like this:
I am thinking not but wanted to double check.
Thanks for your help!
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
4 ANTWORTEN 4
Nachricht 2 von 5
cbcarch
als Antwort auf: LisaDrago
I think you should be able to create a custom fill pattern, make a new ceiling type, and assign the fill pattern to it.
You can use Hatch22 by Mertens3d or another hatch editor to make the pattern.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 5
David_W_Koch
It is entirely possible.  The attached PAT file has a pattern named Ceiling1 that will give you the desired grid pattern.  You will need to create a material that uses this fill pattern and then create a ceiling type that uses that material.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 4 von 5
LisaDrago
als Antwort auf: David_W_Koch
Worked perfectly! Thank you.
LD
Nachricht 5 von 5
jonathan
Hello David,
Letting you know that I appreciate you putting this file together as I was struggling with implementing my understanding of the coding portion of of my ceiling pattern. Mine is similar to what was requested. I adjusted it to be (1) 6 x 48 after (2) 24x48 ceiling tiles. See attached for your reference and use,though you'd be able to make it yourself quickly, but I wanted to give back a little.
Thanks again
