I built the curving wall below using model in place as that seems to be the only way to be able to cut openings in a curved wall. Is that true, or is there another method?
The unfortunate thing is I have a tile pattern that I need to place on a portion of the wall and you are unable to split faces to paint a section of a generic model. Any suggestions? Am I going to have to make another model with voids to achieve that as well?
you can do it by using a Basic Wall ,
Constantin Stroescu
you can also use a Roof By Extrusion and Attach Wall to it...for less complex roof shapes...
Constantin Stroescu
