Hello:
I am trying to create a wall hosted family for a floor to ceiling bookshelf.
Essentially what I would like to do is define the parametrized profile in the family, and then control the arc of the extrusion using another parameter, while having the radius of the hosted wall control the external radius of the bookshelf.
Ideally I would like to be able to use this same family on both straight and curved walls.
Something similar to the below image
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You wrote "...having the radius of the hosted wall control the external radius of the bookshelf"
I don't think you can do this. What I recommend is that you add a parameter to control the arc radius. Create one family for the curved bookshelf and one for the straight one....
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
