Curved Wall (done via Wall-by-Mass) Not Appearing on Section..?!
3 ANTWORTEN 3
Nachricht 1 von 4
pearlofsadness
386 Aufrufe, 3 Antworten
As the image shown. It shows on 3D and Elevation but on Section it just cuts in a way that it does not show the line of the curve... I really do not want to draw the curves manually via Detail/Model Line though... :enttäuschtes_Gesicht:
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: pearlofsadness
Post the file.
Nachricht 3 von 4
pearlofsadness
als Antwort auf: barthbradley
I found out what's wrong! I did not turn on my MASS! My mass was still in the Hidden mode!!! Oh god. So if anyone from the future who isn't able to see their mass's section, remember to turn on ur Mass-view! :leicht_lächelndes_Gesicht:
@barthbradley
Nachricht 4 von 4
You shouldn't need the Mass Category turned ON to see Walls that were created from the Mass.  If some Walls are not showing in Section/Elevation, then they probably weren't created. Maybe you missed those surfaces of the Mass when creating Walls from the other surfaces. Or maybe Wall by [Mass] Face won't work those surfaces. Try Roofs by [Mass] Face.
