Curved Wall and Doors
zs-17
Message 1 of 17
zs-17
I have lots of curved walls with a radius variation. The problem I have is the upper architrave since it's linear. Is there a way to modify the family to force the architrave to follow the wall or I have to turn around the problem?
Accepted solutions (3)
Replies (16)
Message 2 of 17
Message 3 of 17
zs-17
I need more explanation, please.
I didn't understand what you meant with trim as sweep. I understand that I have to create the sweep in the project to follow the curved wall. But how I remove the loaded architrave?
Message 4 of 17
- Create a door type without the frame/trim
- Insert it in a wall
- Create a model in place > category = Doors > start a Sweep > Pick path > Pick the edges of the opening (left, right, top) > finish path > sketch a profile of the door frame/trim (or load a profile family if you have one) > finish sweep > give it a material > finish model in place.
Message 5 of 17
You can delete the trim geometry and symbolic linework in the Family. That would be fastest and easiest. Then reload Door into Project.
Then model the Sweep as an In-Place Component and path your Sweep around the Wall Opening created by the Door.
BTW: Did you go to the Link and Video I provided above?
Message 6 of 17
zs-17
So I load the door family without architrave, then I create a sweep architrave in the project?
Message 7 of 17
zs-17
Do you mean to load a door family without architrave, to create a sweep architrave in the project instead?
Message 8 of 17
zs-17
The link is about how to create a sweep
Message 9 of 17
I'm aware of that. That's what you are asking about.  Get rid of the existing Door Trim Sweep in the Door Family and create a Door Sweep in the Project -- one that will follow the curvature of the Door Opening in the curved Wall. Is that not what you are wanting?
3D Sweep Path around Door Opening in Project Wall:
Message 10 of 17
Yes.
Message 11 of 17
zs-17
Many thanks
Message 12 of 17
b.montarnal
Hey everybody,
Just wanted to share with you another solution.
Because in term of BIM, I don't really like the previous solution. I wanted this door to be managed as every other door, in terms of data structure and information. So I built a door that could be curved, and the angle of the curve is given as an instance parameter.
With the help of some trigonometry formulas, revit manages it pretty well 🙂
I hope it can be useful to someone !
Cheers
Message 13 of 17
revitmuhandis
Can you send the link to download ?
Message 14 of 17
Zachary2_Kirstein
Community Visitor
Community Visitor
Can you share the family download link
Message 15 of 17
cmillerZCS6R
can you share the family for download or send link to where it can be downloaded from?
Message 16 of 17
aidenwangau
Observer
Observer
Curved walls and doors bring elegance and architectural interest to any space, and using quality materials makes all the difference. For curved walls, flexible drywall or kerf-cut plywood paired with framing that matches the intended radius creates a smooth, professional look. When finishing, Period Mouldings offers excellent curved trim and moulding options that conform beautifully to arcs, eliminating gaps and enhancing detail. Curved doors typically require custom construction, whether solid wood or engineered panels, to fit the unique opening. Planning, precise measurements, and experienced installers are essential. With the right materials and craftsmanship, curved elements can transform a room into a striking design statement.
Message 17 of 17
egshyggg
Community Visitor
Community Visitor
