Please see attached image. I have a curved roof that started to look funny out of nowhere. It is supposed to look like what you see circled in red. The highlighted area stops showing the layers correctly. What could be causing this? It appears correct in other areas.
Could you post a 3D section box of the area- to help better explain what you have modelled?
Welp I just found out that when I delete the gutter, the roof looks normal again. I guess the gutter needs to be just line work.
