Curved Panel Mass Facade
2 ANTWORTEN 2
Nachricht 1 von 3
872 Aufrufe, 2 Antworten
Hi all,
Seeking help to model a car park facade.
It basically should look like spaced panels (mullions behind and not at the edges) (as the general facade of the building) but with a stretcher bond pattern and should follow the angle of the car park ramp inside.
Attached pictures for reference: Image 1: general facade of the building ; Image 2: first attempt to the car park facade (mass and 1/2 pattern applied); Image 3: reference image
2 ANTWORTEN 2
Nachricht 2 von 3
MostafaElashmawy
als Antwort auf: Anonymous
You can model it as a curtain wall with no mullions or make an offset to the mullions to be behind the panels. then select the curtain grids and use the add/remove segments to remove parts of the grid to get the required distribution.
Mostafa Elashmawy
Nachricht 3 von 3
martijn_pater
You should be able to align the UV on your mass divided surface to this angle and then apply a patterned surface to achieve what you want... I guess... Or you could possibly use a curtain system for it similar to above.
