curved object
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
362 Aufrufe, 3 Antworten
curved object
What is the best tool to make this piece in to 3D ? ( see attachement )
Do I have to work in project, family or conceptual mass? And wich tool should I use?
Thank you
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Hello! I like a challenge so I've had a shot at modeling your object its probably not 100% (attached so you can see how I've done it)  I've made it as a generic component and used mainly voids and extrusions so nothing too complicated. Hope this helps!
Nachricht 3 von 4
Thank you so much this looks great !
I'm having some issues using the extrusion and void tool..
Can you explain step by step how you did it?
What I did is :
1) extrusion of flat triangle piece
2) void of the 3 holes in the piece
3) tried to void the "curve" in the triangle but I'm struggling doing that part...
Thank you
Have a nice day
Clara
Nachricht 4 von 4
Clara Screencast below, it wasn't quite as neat as it was last time but should give you the idea of how i did it i'm sure you can do better!
