Curved Model Text
Curved Model Text
elky853
Message 1 of 13
Curved Model Text
elky853
I wanna create curved model text on a wall (like signage). I want it curved upwards (see screenshot). I'd appreciate anyone who can help me out with this. Thank you!
  • text
Replies (12)
Message 2 of 13
syman2000
You should check out this video by @Anonymous Medina
https://www.youtube.com/watch?v=rh50vzNSHuM&t=0s
Message 3 of 13
elky853
Thanks @syman2000, I already watched this video but it basically only covers curved model text as in on a curved wall. I'm talking about curved signage like the screenshot attached in the first post.
Message 4 of 13
amarkonathala
hI @elky853 ,
Created Polar array for Model Text and Updated Each letter According to sentence framing
Message 5 of 13
elky853
Thanks @amarkonathala, but I don't really get what you mean by 'updated each letter according to sentence framing'... Can you clarify please?
Thank you
Message 6 of 13
amarkonathala
Ungroup The Array and Update each letter @elky853
Message 7 of 13
elky853
When I create the polar array, it doesn't rotate according to the 'reference' [center] point. Am I missing something? @amarkonathala
Message 8 of 13
elky853
@amarkonathala @syman2000 is there anything I can do?
Message 9 of 13
syman2000
I was using the video I mentioned and do my own spin. In the Family, you define number of alphabet including space to determine your signage text.
Then, remove the repeater
For each alphabet, you define the value. If it is space, you simply delete it to create a space.
The family has a built in arc height and width to get the text arc which you can adjust. Sadly if you want width to be 2m and arc to be 1m, it will break. So you have to set width as 2m while arc to be 1001mm or 999mm to overcome the constraint.
Message 10 of 13
amarkonathala
Yeah @elky853  U should Draw the reference like circle or arc..etc and you have to choose center for that
May be You are missing the place of center of rotation
Message 11 of 13
amarkonathala
@syman2000  The Family is Great!
But We have to create new family For every type of names
Message 12 of 13
_Vijay
I think you can create it as a parametric.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 13 of 13
elky853
Thanks so much @syman2000 for the family!! It's perfect-I simply had to change some of the parameters and I was able to use it in my project! Thank you 😀
