Curved Beams
2 ANTWORTEN 2
Nachricht 1 von 3
380 Aufrufe, 2 Antworten
Curved Beams
Hi,  must be doing something wrong here as my brain doesn't seem to be working today ( at all!! ).  I need to create a large curved arch with sloping legs and struggling to create it using Structural Beam.  I have a reference plane created in the plan view, however, this is not at the same perpendicular angle to the East Elevation - is that the reason I'm struggling?  I have created a new elevation and rotated it to match the plane.  I have then drawn the lines representing the overall shape I need ( shown in the pink red annotation lines ) but when I use the pick line button I can only select the curved element as can be seen in the below image.  When I select either of the sloping straight lines, it says I can't create it.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
It can be done as simply as in the screencast below.
Nachricht 3 von 3
als Antwort auf: ToanDN
Thanks, that has created 3 separate pieces but works.  I have created it using a sweep instead which gives me the single glu-lam I need.  But, I still don't understand why I couldn't select the straight lines but could the curve when I had a sketch to follow of the shape I needed.  Oh well!
