AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
curve walls
2 ANTWORTEN 2
Nachricht 1 von 3
fady_abujamal
160 Aufrufe, 2 Antworten
curve walls
Best practice model  curve wall as per the section with slanted uper part
2 ANTWORTEN 2
Nachricht 2 von 3
ryanZSLF7
als Antwort auf: fady_abujamal
1. I would model the straight section and the slanted sections of your wall as two separate walls.
2. The slanted section can be defined by the wall's property "Cross Section"(within "Cross Section Definition") being changed from "Vertical" to "Slanted."  Then, you can set the exact "Angle From Vertical" you want it to be.
Nachricht 3 von 3
ryanZSLF7
als Antwort auf: ryanZSLF7
Conversely, you can model your wall as a model in place of type "wall".  You could make it a sweep, and have the cross section be the exact shape that you have drawn.
In Foren verƶffentlichen
