I am new to revit..is there a way to change a curved wall to all glass? I thought maybe I could just change the material but no...and the curtain wall doesn't follow the curve when I try to change it. Help please!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Sure. One big panel. No Mullions. Vertical and Horizontal Grid="None". Revit has got one OOTB. "Curtain_Wall-Empty". Just add a Panel to it.
When I say I am new I mean very new haha. I found it under families but it is not an option when selecting wall type?
@Anonymous wrote:When I say I am new I mean very new haha. I found it under families but it is not an option when selecting wall type?
Curtain Wall is a SYSTEM FAMILY. You should have a least one Curtain Wall TYPE in your Project. Duplicate it and change its TYPE Properties to look like this:
Thank you for the Solution Credit, @Anonymous , but I'm thinking I may have misunderstood you. Sounds like you have a curved Basic Wall already placed in your Project and you want to change its Material to Glass. If so, this can easily be accomplished by changing the Material in the Edit Assembly dialog box of the Wall's Type Properties.
