Curtain walling not showing in 'fine view detail' in section
4 ANTWORTEN 4
Nachricht 1 von 5
1513 Aufrufe, 4 Antworten
I am creating section across my model and I notice the curtain walling disappeared from the view whenever the view detail is set to fine or medium. But when I set for coarse the curtain walling can be seen again.
I need to see the curtain walling in fine detail view as I am working on details now.
I have tried to override the curtain walling level of detail in the view template to coarse and keep the view in fine, but it didn't work.
Any ideas?
I have attached the views below.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Hard to tell from your picture. But worth inspecting, would be the Panel Family's Visibility Settings.  Geometry or Symbolic Representation may be tuned off in Fine and Medium Views.
Nachricht 3 von 5
als Antwort auf: barthbradley
Hi Barthbradley,
I tried few things but what worked so far was wall voids. I created wall voids where the sections where cutting the model. I place the voids inside the curtain wall area but not to the full extension of the curtain wall. Please, see picture below.
Not sure what it is, but it is sorted for now.
Nachricht 4 von 5
Corsten.Au
Hello
Theres a 'curtain panel family' used in Curtain wall..
Edit the Curtain Panel Family..
and fix the Visibility of elements..
and reload back to the Project.
heres the reference to see the visibility of elements in the 'Curtain Panel.rfa '
Check which curtain panel is used for that particular Wall... and edit the Curtain panel family for the visibility.Check which curtain panel is used for that particular Wall... and edit the Curtain panel family for the visibility.
Corsten
Building Designer
Nachricht 5 von 5
apexautodesk
Curtain Panels should fix this!
