Hello, I have a question about the appearance of the curtain wall. So, right now in my Revit, it's just looking like this super-thin wall as seen here on the left but I want it to look like the one on the right. Is there a difference or is it because of my view settings? Sorry if the question is actually easy to answer, I'm new.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Type TL in your keyboard and see if helps . Thanks
Thank you but I'm afraid it didn't work. In fact, I don't see anything done to it. May I know what TL is supposed to do? Is something wrong with my Revit settings since this failed? This time, I've also attached the Revit file in case it's my com.
https://drive.google.com/file/d/1hJO-oejKUkgJadgpQGcMc51jITBp9Dp6/view?usp=sharing
If you need a thicker curtain wall you need to
1. Either use thicker/wider Mullions
2. Or Thicker panels
Are you referring to the blue that represents the centerline of the Curtain Wall? Nothing you can do about that. Or are you not able to clearly see the Mullions and Panels in View? If the latter, it may simply be the View Cut Plane is intersecting the Curtain Wall at a bad location. If so, just move the Cut Plane a little.
OMG Thank you, I didn't even notice that the mullions ahhhhhhh. It looks like the tutorial now, and it's working as expected. Thanks!!!!
