I'm trying to create a chain of curtain walls, and can't (as you can see in the attached screenshot).
I have no idea why it won't extend to meet...
Thanks!
Amit
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
How are you trying to connect them? Do you want just one corner mullion?
You can use the shortcut TR and click both curtain walls to meet each other. If you want one corner mullion, delete one of the mullions on the edge and replace the other by a specific corner mullion.
If the endpoints (the dots) of the CWs overlap each other, just select the end mullion, unpin and change its Type to a corner Type.
