Curtain wall with changing bottom level
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1595 Aufrufe, 3 Antworten
Hi!
I was trying create a cutain wall as the screenshot below shows. The wider piece is for door that will be place on the floor, and the rest of the pieces are supposed to sit on a 100mm high curb (I haven't build the curb so they are floating above ground right now) .  When I tried to place mullions on the grid and this is what heppened. The central line of the mullion should be aligned with the vertical grid line, but the two short mullions are not. Does anyone how to let the mullion next to the door go straight down to the ground?  Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Below are are two methods, both accomplish the same outcome:
- unlock and remove the unwanted mullions and panels
https://knowledge.autodesk.com/community/screencast/e043d9c0-b913-42d9-93da-984e518e5f29
- edit profile
https://knowledge.autodesk.com/community/screencast/449a26aa-9222-448b-8da1-ef3f38765512
Nachricht 3 von 4
SteveKStafford
I like to swap out the panel at the door for the "Empty Panel" and sketch a separate curtain wall type in the opening that is created. I find I can reliably avoid mullion and curtain grid warnings that many users run into while using Edit Profile. Both can work but it does require some careful layout and other users can easily mess it up. The attached image is using a 100mm curb that the project I was involved with was using too.
Steve Stafford
Nachricht 4 von 4
als Antwort auf: ToanDN
Thank you! This answer my question!
