Ok, so way I figured the best way to a do a Window Type Schedule for curtain walls is to: create new elevation view, hide everything other than curtain wall mullions, and dimension... Problem: some mullions don't clean properly, especially at intersection non perpendicular angles. See pasted images. Is there a 'smart' way of cleaning this up? Or should I do a hot podge of hide, wipeouts, and detail lines?
The definition of insanity is doing the same thing over and over again and expecting different results
