Curtain Wall Tag Linked To Enlarged Elevation??
1 ANTWORT 1
Nachricht 1 von 2
chris.harmon8KMPL
120 Aufrufe, 1 Antwort
I am trying to create a wall tag family that will link to a different sheet containing a blow up of the wall elevation. My company does this to locate Curtain Wall openings on overall building elevations and then when you click on the tag in the PDF, it sends you to a blow up elevation of the Curtain Wall frame. I'm not even sure it's possible at this point. Any help would be greatly appreciated!
Thanks!
Chris
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: chris.harmon8KMPL
You could do the opposite - create an elevation mark that looks like a curtain wall tag and match the elevation number or elevation name with the curtain wall identity.  That would work in Revit but I am not sure about hyperlinking in exported PDF though.  I have never gotten it to work with Export to PDF or Print to Adobe PDF.
