Curtain wall shadow
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1362 Aufrufe, 2 Antworten
Curtain wall shadow
Hi, I want to add shadow in the elevation view of curtain wall and i have changed the transparent of curtain wall and changed the spandrel panels' material into Metal. While when I turned the shadow on, both  glass panels and metal panels are all transparent. How can i change it?
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: Anonymous
hello, can you share the file so we can check. or check your visual style > graphic display options > model display > transparency > set to 0.  thanks
Nachricht 3 von 3
Corsten.Au
use different material for glass panel and spandrel
1. Glass panel - Transparent material, Glass
2. Spandrel - opaque , Metal etc..
Corsten
Building Designer
