curtain wall rotate issue with constraints
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
htews
283 Aufrufe, 1 Antwort
When I copy a curtain wall entry system to a new location and try to rotate it 90d, I get an error message "constraints are not satisfied".  *note - the spacing between the door jambs are locked*
when I unlock/remove the constraints, I can rotate without a problem.
my question is,  what does the constraints got to do with anything if the entire wall is being rotated?
thank you.
1 ANTWORT 1
Nachricht 2 von 2
cbcarch
als Antwort auf: htews
Probably because the constraints were set up in the original CW, you then copied it, rotated, and Revit knows the difference and throws a warning.
Try using Create Similar by right-clicking on the CW, and see if the constraints error still happens.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
