Hi there!
I have a project where I am using both window families and curtain walls to create interior windows.
I've used "Edit in Place" to the glazing in the curtain wall to change its family category to windows in order to have both windows and curtain walls to be in the same schedule.
The problem is, the curtain walls lack information compared to the window families.
Is there a way where I could have curtain walls report to the window schedule and have the "To Room" and "From Room" show up? It would be great if I could somehow place room calculation points for the curtain wall panels, but I assume that's impossible.
My last resort is switching out all the curtain walls and creating individual window families in place..😢
Solved by barthbradley. Go to Solution.
What about using a Curtain Wall Window Family with the Room Calculation Point activated in it?
FWIW, I'm not having any issues with your workflow. Set your Computations to Area and Volume, and raise your Rooms' Limit Offset.
