Dear all,
Thank you for your help,
I would like to modify the curtain wall system in a way that I can connect 2 curtain walls (2 slightly different planes) with a rectangular mullion aligned to one of the 2 planes. I used an L shape corner mullion, however, the result is a trapezoidal mullion and I would like to achieve a rectangular shape.
Current solution does not satisfy the design boundaries
Goal mullion in between 2 curtain wall instances
Note 1: I tried to use the corner quad mullion but it didn't work
Note 2: I must keep 20mm gap in between the glass panels of the curtain glass.
Thank you again for your help.
Make the corner a short curtain wall (20 mm long) with one interior mullion of the custom shape you show, then change the panel type to Empty System Panel.
