Before anything else, I go to Families > Curtain panel > System panel > Entrance, to modify the properties of curtain wall, is that the correct place to modify the glazing material?
For example, my curtain wall thickness must be 12mm, so at the thickness section, I set it as 12mm. However, at the analytical construction section, I choose the type of material I want, some of them have their own dimension, some of them have no. For those have their own dimension, for example, Uncoated single glazing -1/4 thick - clear glass.
If I set the thickness of my section to 12mm, and also use Uncoated single glazing -1/4 thick - clear glass at the same time, what would the thickness be?
Since I choose Uncoated single glazing -1/4 thick - clear glass because that is the properties I want, however, when I go to energy, lighting analysis. I have to preset something before running them, I somewhat see that they got pre-defined some properties already. So I am not sure which properties is being run under the analysis.
It is better you can explain it in words instead of giving me links to read.
Appreciate your help.
Wei Xian.
