Is there a way or a place where I can to download custom Curtain grid patterns other than those in the drop down menu when I divide a surface?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
It is easy to generate the surface pattern that you want...In conceptual mass
1. make a vertical surface
2. Place a ref plane parallel to it call it say (Canvas)
3. draw reference line to make the pattern you want on the Canvas plane
4. Divide the surface u created in 1 and switch off the grids
5. Use intersects and select the ref line then click finish
Move/slide the reference lines and the pattern changes...
You can do that also in combination with the existing patterns in the patter type selector to get even more variations
And of course you can do the above using dynamo
That could be a solution for this project, I have this arabic patterns which I need to use on a curtain wall. I thought there is a way to add to revits library.
I haven't really used conceptual massing much, can this be saved as a template to use on another project ?
No not really you cant...well, unless you use Dynamo. You will have the graph to regenerate the same on other projects.
Outcome of the above is something similar to the below combining interests with an OOTB Pattern
Please suggest the way to achieve attached staggered pattern for curtain wall.
